S
scoot
hi folks is the handbrake cables the same for all the micra k10,s thanks
no actually the handbrake cable is different for the pre facelift than the facelift as me an mat found out when i needed to change the old car once on the car you cant take it off and back on again where as as far as i know for a face lift you can
It would help to differentiate between the 3 cables on the handbrake…I can see this getting confusing...LOL
I have the face lift (“facelift” HAHAHA lol what a phrase)
Cable to the rear OS :
Same for all ? Is definately removable atthe mid coupling. not sure if it is removable at wheel end
Cable to the rear NS
Centre cable:
Same for all....not too sure about this ? Is definately removable atthe mid coupling. ….Is riveted to the handbrake lever though. I had to drill/saw mine out when I had to replace this cable…..& when I got the new one fitted, I think it was a little too long?? (had a kink in the outer sheath when fitted
its the way in which the cable mounts inside mate, also the way in which the hub inside is mounted its a bit hard to explain with out a picture mate but they are quite different
more than likely they wont fit then mate, the FL cable does not bolt onto the hub (although it sort of looks like it does) it works alot like a bicycle brake cable where as the PFL cable mounts to the hub slightly differnetly, if you need help getting the right cable let me know, iknow a good online shop that does them very cheap.
i wish i had a picture of an open hub to help explain better
