I have a problem with my nearside headlight. it looked as if the main headlight element had gone so i checked the bulb and it was fine on the opposite side. the wiring connector at the back of the bulb looked like it had melted a bit, so i got a new one and problem is still the same. upon further investigation of the good headlight workings, the front half of the bulb illuminates on main headlight, then when you switch to full beam that bit goes off and the back bit illuminates instead. on the problem side. the full beam bit works as it should but on main headlight half of the front element is illuminated at half light and so is the rear element (at half light) thereby making the headlight look dimmer than the other correct side. any thoughts please i'm baffled (and wellskit)
