CMF_GT
» CMF MemberI was looking on rallynuts for some new brakes and seen that there is GTi-R brakes for the K11, I know that’s not new to some of you but Iv never seen them. Has anyone got pics off them and where can you get the calipers from.
Brendon WROTE:
"just ge sure they will be ok. coz they designed to carry a car which weighs 1200kg so it takes a lot longer for them to heat up. cisco had some on his car and they did not heat up enough and brake dust would build on the disc resulting in shudder. just 15inch wheels are a minimum. well you can have 14 but tight fit. i own a GTIR and i was thinkin of getting some of that rally nuts stuff. is it any good??
Yom WROTE:
"OH snap!
Thats no good.
Might have to stick with the tried and true Lucas pads.
PS: don't get the ferodo ds2500 pads whatever you do. for the ad22vf they're actually cut from a larger pad and the backplate has pressed indent thingos in it, positioned in really bad places. So what happens is that the piston side pad will bend around the piston. This means you get good brakes for about 31.834seconds and then your brakes are rat**** and your rotors have just been chewed up by metal to metal contact.
a few of the turbo pulsar boys have just learnt this expensive lesson and are chasing ferodo for compensation.
