Greddy E-Manage
CMF_evade
If you want to turbo your car go for a full aftermarket ecu.
You can get the emanage to work but its a bit of fiddling around and its easier to just get a full ecu in the first place. (I learnt my lesson...)
CMF_underconstruction
i am do know what to do. i can get a greddy e-manange + a garrett m27 turbo(new stuff) but also for the same money i can get a greddy e-manange(new) + set of 40 mm throttle bodies whit injectors and a maf sensor but whitout a manifold.
please help what should i get?
CMF_lam.666
whats everyones opinion on the emanage for a quad setup on a cg13de?
are they easy to tune by the ordinary DIYer?
and with the emanage, just to confirm it uses the stock settings in the ecu as its base and just tune on top of the for air / fuel, can you increase the rev cut?
what sort of tuning program comes with the package, or do you have to buy "e0-1, PRofec e-01 programmer or our PC-Windows based "e-Manage Support Tool"
people on the forum who are using the emanage, how have you found it?
