mine fitted no prob.
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-12#post-422391
fronts should simply be remove original struts and bolt the BC straight in and the hub bolt holes should line up.
for the rears, disconnect the panhard, remove old dampers, disconnect the rear brakes to prevent stretching the hose, drop the axle, remove old springs & rubber seats.
now on the coilovers, set the rear spring perch ring that it sits on cos access to it after it's bolted on is difficult (this sets the rear height, mine's set at 45mm from top of the cylinder to the seat), lock it.
then place the perch assembly onto the circular hole on the axle where the spring used to sit on, then bolt the lower securing washer plate from underneath so now the perch assembly and lower washer sandwiches the axle.
with the perch assembly secured, fit the upper & lower plastic ends onto the ends of the rear spring, this stops the bare spring rattling against the metal chassis.
fit the springs onto the perch assembly seat. the narrow lower end fits onto the perch assembly while the wider top end fits under the chassis. now while you slowly jack up the axle, keep an eye on guiding the top of the springs towards the underside cavity of the chassis. when any one of the rear springs begin to touch the chassis, give it a wiggle to make sure it's centralised onto the chassis cup and not jammed at some croocked angle, then continue jacking till it begins to lift the chassis.
with the springs fitted and under weight of car, fit the dampers. then everything else.
once fitted, get it setup & balanced correctly for your configuration asap to get the most performance out of them, that's the main purpose of a fully adjustable coilover.
to protect ur £££ coilovers long term, I'd suggest thinking bout making some covers.
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-19#post-446325
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-24#post-454436
