Good service kit?
Seems resonable to me :)
Have a look into a new dizzy cap too only cheap unless you wanna clean your old one up. All helps
What's one of those mate?
I have two other problems to look into:
Squeels on start up for a little bit when cold?
Constant exhaust heat shield rattle! (The one right at the front which you can see when looking under the front bumper!)
Its the black distributor cap that your ht leads go into. Do a quick search :)
The squeal is probably your belts at a guess. Give em squirt of wd40... and check their tension and condition
Your heat shield rattle might be a loose bolt or rusted away. Give it a wiggle and see :)
