Hi lads , just wondering whats the longest second gear ratio that can fit a k11 1.0 gearbox ? Thanks for any help!
Can you post up the ratio's for 1275 too please.
does this mean me bolting a cga3 to my coilpack 1.0l box has no difference but 5th gear?2nd in 1275 is 1.955. 2nd from the 1348 is what you want at 1.782. although I see the 1348 has the same ratios as the from 2000 on 1.0L apart from having a 3,895 final drive.
no, it means you have the same clusters, but a lower ratio diffdoes this mean me bolting a cga3 to my coilpack 1.0l box has no difference but 5th gear?
whaty does this mean in terms of acceleration, top end speed and what not lolno, it means you have the same clusters, but a lower ratio diff
your 1.0 box is like fitting small wheels to a 1.4 k11whaty does this mean in terms of acceleration, top end speed and what not lol
i mean like acceleration or not as quick top end speed, i didnt word that very well sorry :/ lol i aint that stupid well i hope not seeing as im a mechanic lolNo it means instead of having a 998cc engine you now have a 1348cc engine
which in turn does what is what im asking frank? is it worth getting a 1.4 box?your 1.0 box is like fitting small wheels to a 1.4 k11
well if you fit smaller wheels the rpm is higher eh, so a 1.4 box would drop your revswhich in turn does what is what im asking frank? is it worth getting a 1.4 box?
could this along with the need for a new maf explain the ####ty fuel consumption as i generally just do short start stop journeys?
so for better economy id be better off with the 1.4 box?It won't help. My 1275 does between 45 and 50 mpg, I get 50 mpg+ on long runs at 70+ without trouble.
nice thanks for the help possibly be done when funds allowYes, without a doubt.
so the 2nd gear in the k10 gearbox is longer than the k11 2nd gear?You racing ovals?? for 1/4 mile oval in rosegreen here in ireland i use the boxy k10 4 speed gearbox on the cg10, works perfectly....i just get valve bounce at the very last moment before its time to back off for the turn, according to rev counter thats 7900rpm (but probably closer to 7500). You need the the k10 4 speed clutch plate but need the early cg10 flywheel.
Only problem is that the gap between 1st and 2nd is quite big, i find i have to slip the clutch to keep the revs up when going from 1st to 2nd off the startline. Tough little gearbox too, have not broke one yet (although the cg13 with 12:1 cr and bike carbs with 270 cams and custom exhaust manifold that will be done soon might change that...lol )
same as the 5 speed according to haynes natewhats the gear ratios for the 4 speed k10 gearbox lads?
Yes mate but we have a 1998 hotrod car and we need a longer second gear so if i fitted a k10 gearbox would i have a longer second gear?same as the 5 speed according to haynes nate
no, but 3rd 4th and 5th gears are tallerso the 2nd gear in the k10 gearbox is longer than the k11 2nd gear?
the k10 type 41 isin a 4 speed k10 gearbox frank?
Thanks mate98 was the changeover year for 1.0,s eh nate (pre-facelift type 41 or facelift type 30) you might be best to fit the type 30 box if yours is pre-face, the 4.65 diff one, and use 3rd gear ?
Ah, so now i see the difference between type 41 and type 30 ratios, and the type 30 has a 4.65 final drive. What is the final drive in the type 41 then?
HAYNES MANUAL
Gear Ratio's
998cc Models:
Upto 1998 type 41
1st 3.412 : 1
2nd 1.958 : 1
3rd 1.323 : 1
4th 1.028 : 1
5th 0.850 : 1
final drive 4.050 : 1
1998 to 2000
1st 3.062 : 1
2nd 1.826 : 1
3rd 1.207 : 1
4th 0.927 : 1
5th 0.756 : 1
final drive 4.471: 1
From 2000 on
1st 3.333 : 1
2nd 1.782 : 1
3rd 1.207 : 1
4th 0.902 : 1
5th 0.756 : 1
final drive 4.471:1
ahh, my bad, i think matt did say 4.47Wher's the 4.65 final drive ratio gone now then 1275?
