gearbox questions
I have a v reg 1999 micra which is a facelift distributor engine which has the gearbox with an electronic speedo sensor. I am changing the gearbox and bought one with the old non electronic speedo cable and was wondering if i changed the whole cable it would work with the clocks are is there alot more too it?
there is a slight difference in the dia of the senders apparently daniel, some info in polly,s blog iirc
is the one you bought a 1.3 g/box ?
