Gearbox oil capacity
I've just been to buy some gearbox oil and the only one my local motor factors has is ep80w90 gl5 I was lead to believe micras need gl4.
Would gl5 be ok or not?
Matt
you need 75w90 gl4.
c/p from the FAQ section on this site:
Question?
What oils are recommended to use in a Nissan Micra?
Answer(s):
K10
engine oil of 10/40 semi synthetic, gearbox oil of 80/90 transmission oil(manuel box) atf (automatic transmission fluid for autos).
K11
engine oil of 10/40 semi synthetic, gearbox oil of 75/90 semi synthetic (manuel box) atf for automatics, power steering fluid is atf also.
Ok, they only had gl5 of that too. The computer bought up 80/90 oil in the motor factors. I guess there isn't a massive difference in the viscosities between 75 and 80. But what's the business with gl4/5?
The guy on the counter just said better quality but I wanted to check it out first.
Difference in viscosity between 75 and 80? MASSIVE! I had 80w90 in my car and it was impossible to shift on a cold morning. Now with 75w90 its much much better. The specs show the same story:
75w90:
Viscosity at 40°C in mm2/s: 88
80w90:
Viscosity at 40°C in mm2/s: 159
As you can see the 75 is better suited for low temperatures. This is a comparison between 2 oils of the same manufacturer.
GL5 oil is more agressive to some parts of the gearbox especially the brass parts! Avoid!
Yo guy at the counter knows nothing i guess :)
75w90:
80w90:
No he doesn't know alot. Not the normal motor factors I use just called in on my lunch. They are pretty cheap for something's but his knowledge is poor.
I will go to the usual place tomorrow and get some 75/90.
The car will be mainly used for my fiancé to learn in (and me to rag around:grinning:) so the easier the gear change the better!
Thanks for the advice!
Matt
