gearbox linkage help
is there a diagram for the gear box linkage i've jus swapped the engine in my micra due to cam chain failure when changing the clutch realised that the engine sold to me was a 1.0 not 1.3 i have i all running but not sure how to mate the linkages up an ideas?
Does anyone know if you can get new bushes for the linkage to selector rod joint (the swivel joint). The ones in my car are quite worn, slackened off the bolt a bit, helped for a while but now its a bit too loose.
what box is on it??? if its the 1.0 box then unlucky!!! youll need to either get the 1.3 gear linkage and rod and swap them or put a 1.3 box back on. if its a 1.0 box then its straightforward ;)
