Bought the micra on Sunday in good faith and i was told it had a new clutch put in it (1.0l s-reg)
Now my query is that the gear stick seems to be out of line. Hard to explain but i will try me best.
1st gear is where 3rd is and 2nd gear is were forth gear would be.
Seems to have moved to the right some how. Is there anyway i can rectify this? Or is the gearbox shot?
I had a look under the car but couldnt really see much as the heat shield was covering the gear stick bit. All i could see was two bars coming out and one with a knuckle type joint on it. All looked clean and in good order. There seems to be a nut on the gearbox itself i wonder if thats a adjuster?
Cheers in advance guys!
Michael.
Michael.
