CMF_lam.666
» CMF Memberhi micranites
just looking for some assistance, just installed my gearbox, have not filled it with oil nor fitted the driveshafts/cvs yet.
went to turn the car on, because the motor and the starter motor should work without any gearbox oil... im assuming... but the car wont start, when i go to turn the key i get one audible *click* which sounds like the starter motor is either stuck / not engaging with the flywheel / flywheel is stuck / or not on properly...
i think that the car is in neutral, even if it was in gear, with no driveshafts no wheels car should still start...
is there a special way to fit on the gearbox, or should it just slip in with no trouble and start...
if anyone has a picture they can up of the workshop or haynes manual it would be appreciated.
