Gear shifter question
  • Thread starter Deleted member 31521
  • Start date
D
Looking for more info for changing the bushings inside the unit.
When looking around for some guides for this I do not find any.
Can see a short shifter mod on here and the box is cut in half. (This doesn't really provide the info needed)
What I'm trying to find out is how can I get inside to replace the parts. (Without destroying the casing)
I want to be able to see if it's possible to replace the bushes. That should be simple enough
The only solution I can think of so far is to purchase a new unit and cut out the side or remove the bottom. (Whatever it takes to renew them)
The cables seem to be fine as I already checked those and they do not appear to be worn at gear box.
Sent from my ASUS_T00P using Micra Sports Club mobile app
