I might be buying the ga16 k11 i was offerd last month....it has the cg13de box mounted to it.
Is this correct and will the gearbox and clutch all work ok?
It drives as i tested it yesterday.
He is also running the k11 ecu but again is this ok or can i plumb in my megasquirt ecu and create my own base map?
