Been doing research on this and am planning a 1.6 swap in the summer but looking clarification on two things.
1. I have a 2000 Facelift K11 with coil pack engine and I right in thinking I can use the gearbox in this with the 1.6 engine as it is similar to the cg13 ones but with different gear ratios? I am not looking for top speed so am thinking this will give me the best acceleration.
2. If unable to use my own gearbox and have to use either a primera or almera gearbox how will the speedo work? Is it a case of using the speedo clocks out of these and modding them to fit the micra dash.
I have used the search function and cant seem to find these answers. I also know that engine mounts and etc have to be modified to fit and this isn't a problem.
Thanks for looking
Thanks for looking
