If i run a 1.3 litre CG on a 1.0 ECU (bosch motoronic post 2000 to be precise)... it will run lean.
now the obvious idea would be to use a cga3de ecu (cg13 wont fit loom) but as nats is a pain and these are very rare would the following idea work:
keep the 1.0 ecu, stick some GA16 injectors in.
would that get the fuelling nearer to what it should be?
opinions please!
also please also post if you have any spare ga16 injectors lying around.
opinions please!
