CMF_sodaniel
» CMF MemberHey guys, need a little help regarding Injectors. I did some research on this forum regarding the GA15 TB install, and according to some members, because of the increased intake capacity, the injectors wouldn’t be up to the task at top revs… A few guys said that the GA15 or GA16 injectors would bolt up no worries, and would do the task…
So I went and ordered a GA15 TB, as well as GA16 injectors (off the locally sold Pulsar) from Pulsar Parts in SA… However, doesn’t seem like these injectors are compatible with the CG13!
Can anyone clarify, that in the pic below, that these are GA16 injectors? (left is standard CG13 injectors, pink one is GA16)
As you can see the dilemma below is that it does not bolt into the fuel rail…
Does anyone have experience with changing injectors using the standard CG13 fuel rail? If so, what injectors did you use? Were they ‘plug-and-play’?
Please shed some light, cheers!
Daniel
Daniel
