jamieccc Ex. Club Member Jun 25, 2015 #1 from the research I've done, am I right in saying a ga16de clutch, pressure plate and flywheel will fit onto a cg13de? I understand the ga flywheel is heavier but I can always get that machined.
OP OP jamieccc Ex. Club Member Jun 25, 2015 #3 If its a bigger centre bore does it still fit on the shaft correct? Sent from my iPhone using Tapatalk
frank Club Member Jun 26, 2015 #4 spigot ring needed ideally mate, (unlike roadwheels) flywheels are hubcentric
OP OP jamieccc Ex. Club Member Jun 26, 2015 #5 You havent got any pictures of one fitted with a spigot have you? Did baguette use a spigot on his when he did it? Sent from my iPhone using Tapatalk
r-reg-sr ------- Site Supporter Jun 26, 2015 #6 Bright Spark Racing can do one. BSR on here .actually need to contact them myself.
OP OP jamieccc Ex. Club Member Jun 26, 2015 #7 They can do a spigot? Sent from my iPhone using Tapatalk
r-reg-sr ------- Site Supporter Jun 26, 2015 #8 you should make a wanted thread after reading baguettes blog though he move it up to turbo i think it's SAFER with it
