GA14 clutch
This is for those who have used or are using one, what year range is it that you're using?
95-97 180mm or 97-2000 190mm
Also if anyone has used a 190mm clutch was there any issues or modifications needed?
Im using the 180mm clutch on my grey micra, all plug&play on the 1.3 fly/box, feels very good and the pedal is very light.
The 190mm clutch should be similar to the one i have on the SR, i would say that you have to swap the flywheel to install it.
