G4 Coilover owners Help
CMF_eeden
any body have g4 coilovers on the forum?
i would like to lower the rear more. but currently its already on the lowest setting. is there any way to lower the car more and safly in doing so.
i was thinking about removing the bottom spring porch, is it safe to do that?
thanks
CMF_deNs
If by "porch" you mean the adjustable seat the spring sits in, then I'd be seriously checking your shocks to see how much travel they have - you may end up hitting the bumpstops if it's too low. Being that low the geometry could be out as well (though it is the rear so it might not be too bad) so I'd get an alignment straight after that to check how things are afterwards.
---dens
