i have a k11 which did have a full janspeed system on it, manifold,decat,centre and back box. after having it for about 3 years the back box got a hole in it which you could virtually crawl through (couldn't be repaired) so because i needed if fixing fast i took it to the local garage and had a standard back box and centre section fitted. ever since between about 2500 revs to about 3000 the exhaust makes a rly loud raspy/rattle noise which im pretty sure is coming from the back box, is this because im running it straight through into a standard back box and it cant cope or could this just be a faulty back box???? cheers
