Hello all, another couple of questions for everyone:wasntme: I just recently got 5w-30 full synthetic oil... I'm not sure what my car thinks of it though... It seems to be VERY lazy in the lower rpm band where before it was not... When it was idling (at about 700rpm) and I gave it the SLIGHTEST bit of gas, it died. Before I introduced full synthetic it had no problems like this. I also had an engine flush performed. I'm not sure how old the pan is though, hopefully the chemicals they used didn't muck it up Another problem I ran into (this was my fault) was the rad was extremely low on water and the temp gauge went past the 3/4 mark... My engine felt like it was mis-firing every 5 minutes... I was on a highway going ~100km/h and the car would lose all power for a second and dive forward, then recover. Which brings me to another thought of, is my clutch dying! It has been slipping (mostly on take-offs) and even when I pop the clutch it won't really jerk the car, it'll just rev down.
So things that I need advice on lol:
-Full synthetic 5w-30 good/bad for my 1.2L engine that has 294,300km on it
-Did I damage something from overheating it
-Is my clutch on its way out
-How do you tell if your cat converter is in need of replacement, currently the support has broken off and is rattling against the piping.
I've got the next 10 days off, and it's supposed to be beautiful weather, so I'm going to check my spark plugs/dizzy/everything associated with them and see if anything is worn.
Thanks in advance!
Thanks in advance!
