superls
K10 Tuner
hi boys and girls, im here with yout another problem.
i need to increse the fuel pressure of the standard fuel pump to around 10psi or get another mechanical one off of another car and 'retro fit' it or get an electric one.
im not 100% sure how the standard pump works so unsure if it can be turned up?
had a quick look for different mechanical pumps but not seen anything with enough pressure.
also had a quick look at electric pumps and there seems to be 2 main types, upto about 5psi and then jumps right up to 3-5 bar (40 - 70 ish psi) with not alot inbertween.
i suppose what i could do is get a high pressure one say 3 bar and then get an adjustable fuel pressure regulator but thats seems to be the most expensive way of doing things.
also on an unrelated note, how is the boost pressure controlled on a turbo? i.e. limit it to 5psi or similar?
cheers
cheers
