SuperUno
Buy & Sell Member
I went to start the Girlfriends Micra this morning (to take her to the station) and it failed to start. After a few tries i gave up and used my car. When i got back i tried again, and after a few more i tries i had success.
I think the fuel pump relay (is there more than one ?) are playing up, when starting i think they are failing to 'stay-on' and i think from listening to them when it does work that they should 'switch over' and this is point at which they stop working. It is very random over when they do and don't work. Car is quite well used 100K plus miles.
Is it likely to be the relays at fault or more likely to be the wiring to the relays at fault (i can see a past owner has bodged the wiring here before).
Thanks in advance
Thanks in advance
