Fuel meter not working.
CMF_Nnick
Hi,
I was wondering if anyone could help me out. I have a 1996 nissan march for the japanese market. I recently had to change the fuel pump (over the weekend) and now it seems as though my fuel meter is not reading correctly. The other day I ran out of gas on a hill and it was reading half tank. Today I was watching it and when i am ascending an incline the meter goes to the 1/4 mark and when I was going downhill the meter went back to half way.
Where is the fuel sensor located and how easy is it to replace one?
I realised the mechanic left the fuel pump floating in the tank (it is in some sort of plastic housing) but it is not attached to a side .. is this normal?
Any help would be appreciated.
Thanks.
CMF_nz_aj
I think there are two different Japanese fuel level senders, with different resistance ranges.
When I swapped instrument binnacles I observed a similar problem.
The fuel level sender is mounted with the fuel pump.
If you swapped pumps, you probably also swapped senders.
CMF_Nnick
Thanks for the reply nz aj.
So does that mean I need to purchase an original nissan fuel pump for my fuel levels to be correct?
