fuel injectors
jim_bling
what fuel injectors are a direct fit for my 1.4 engine would 2.0 injectors over fuel my car or would 1.6 ones be better any one got some for sale
no bigger injectors will be fine, sr20de ones or bigger not needed, but will be ok. got for ga16de ones...will be ok esp if your running a janspeed manifold and exhaust the std injectors are nearly maxing out (on cg10 and cga13de engines) so ga16 should be perfect.
Later type CG10 and CGA3 engines use different ecu's, maf's and injectors......they are top feed, so anything for the older pre 2000 CG10/CG13 engines, (GA16DE), will not be applicable.
Also simply bolting something on hoping it will work is not a way forward regardless of modifications.
oh yearh fortgot to say it will need mapping up, would be a good time to get a throttle body aswell... could you not use almera N16 injectors? or new shape primera ones?
