T
thekore
Hi Guys,
I'm having an issue with my fuel filler pipe neck, the type of issue that results in leaving a small pool of petrol on the forecourt everytime I go to fill her up. The filler pipe is quite corroded and can easily be seen from under the rear passenger wheel arch. Its trickling around the neck of the filler just under the overflow pipe.
Now is it easy to replace this or will Gun Gum or some other repair paste be able to fix this? Obviously I dont need a air tight seal, but I need a seal strong enough to stop flow. Recommendations would be apprieciated
Thanks in advance
Thanks in advance
