FS: n14 pulsar 1.6 front brake callipers
CMF_qwerty132
Hey
I might be interested...
What else is needed for the conversion? Other than discs, pads and calipers?
Have you had these fitted? Does it change the pedal feel much?
qwerty132
CMF_jay85
no they have never been fitted to a car. so i have no idea what the pedal feels like afterwards.
from what i have read all u need is a small washer as well. that goes between the calliper and the mounting bracket, it centres the calliper and the disc
smidge
you need a 1mm thick washer, take a caliper bolt with you to size it properly
changes the pedal feel alot but who cares when you can pull up the car time and time again in about 70% of the distance you used to need
that said, my original pads were pretty shagged but the difference is still awesome
i personally like a brake pedal that needsa bit of effort as ou get better feedback of whats happening
a worthwhile upgrade, and only a little more than what i paid for my calipers, but then i had to replace all the seals cause they were rooted
