FS: Low-boost fuel setup (Haltech F5, Rail, etc.)
CMF_deNs
Ok so, what we have here is:
-Haltech F5 Fuel-Only ECU + Wiring loom
-CG13 Throttlebody with extra Camry SV21 injector
-CG13 Fuel Rail + Standard injectors
I believe it originated with Family Hack/White Knight and is likely identical to the setup that Mipcar's had running nicely in his car for years. I have no use for this setup as I've gone down a different route.
For those that aren't familiar with what a 5th Injector setup, it's a way to increase fuel for when needed like if running a Turbo setup - when a certain boost level is detected by the Haltech ECU (~3-4psi I believe), the 5th injector drilled into the Throttlebody kicks in and supplies the extra fuel needed to keep mixtures correct when boosting :) It's an inexpensive way to go boosted that's for sure.
Images:
Postage: Pickup preferred but will post at buyer's expense.
$300 ONO
---dens
CMF_mipcar
I go with Dens appraisal of this. Very easy/simple setup.
Only niggle I have is a little roughness when hovering around the 3,000 rpm mark. It might be the point where the 5th injector begins cutting in/out.. Above/below that it's fine.
Mychael
