CMF_deNs
» CMF MemberFRP Fibreglass Flares
Imported these from Japan a few years back and they’ve just been sitting under the house, wrapped up, never used. They are <em>brand new</em> and have never been fitted to a car. They’re gel coated in white, ready to be painted or used as-is Also comes with a rubber sealing strip thing.
They’re just taking up space. Cost me quite a lot more to import them, but my loss is your gain Would prefer pickup for these as they’re a big item but may post them also.
<center>
<img src="https://lh3.googleusercontent.com/-...ABJc/WPcMlA18DJ8/s400/IMG_20130210_023113.jpg"/> <img src="https://lh3.googleusercontent.com/-...ABJM/MjC08mCkT4k/s400/IMG_20130210_023129.jpg"/>
</center>
Here’s what your K11 could look like with these flares:
<center>
<a href="http://smg.photobucket.com/albums/v234/Anode/zest4.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v234/Anode/th_zest4.jpg" border="0" alt="Photobucket" ></a> <a href="http://smg.photobucket.com/albums/v234/Anode/158bae54.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v234/Anode/th_158bae54.jpg" border="0" alt="Photobucket" ></a> <a href="http://smg.photobucket.com/albums/v234/Anode/t=p11.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v234/Anode/th_p11.jpg" border="0" alt="Photobucket" ></a> <a href="http://smg.photobucket.com/albums/v234/Anode/neatstyle3.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v234/Anode/th_neatstyle3.jpg" border="0" alt="Photobucket" ></a>
</center>
$400
__________
H4 HID Kit including 4300K bulbs and ballasts
This is a kit that I pulled out of my K11 which I used with standard K11 headlights. They would also work in aftermarket DEPO lights but with any new bulb you tend to need to adjust them. They were working when they were pulled. There’s plenty of places around the headlight to bolt in the ballasts, either out of sight or not so they’re an easy fit if you’re worried about that. Massively bright and the 4300K bulbs give off a pure-white looking beam.
<center>
<img src="https://lh5.googleusercontent.com/-...ABMI/RNeHPxgDKo8/s400/IMG_20130212_230749.jpg"/> <img src="https://lh5.googleusercontent.com/-...ABMM/CiKO2gcsPZ4/s400/IMG_20130212_230802.jpg"/>
</center>
Note: Second ballast not shown in the second image, but will be included
$50
__________
GFB Atomic Bleed Valve - Manual Boost Controller
This device is a simple and effective tool for controlling the level of boost for your turbocharged engine. It’s adjusted with a small screw on the top of it and connects between the wastegate and the piping after the turbo.
Haven't taken a photo but it looks just like this:
<center>
<img src="http://www.aucklandmotorsport.co.nz...magecache/product/Atomic Boost Controller.jpg"/>
</center>
$20
____________
Postage is not included in the prices above. In the case of the extractors and flares, postage would have to be organised by the buyer (courier, etc.).
Feel free to shout out if you've got any questions about the above
____________
Sold items:
Bosch 040 Motorsport Fuel Pump
Perfect for upgrading the original pump of your K11 (in a BIG way). Have modified a K11 fuel pump cradle to allow the pump to just be slotted in place of the original. I never got around to using this. Will post at buyers expense.
<center>
<img src="https://lh3.googleusercontent.com/-5E-j2sDcujM/URBPg28XQaI/AAAAAAAABGA/AqTi8GsF6mo/s400/4.jpg"/> <img src="https://lh4.googleusercontent.com/-uf7VEWTm2Mk/URBPg7M0sDI/AAAAAAAABF8/sbJ3mnO9b54/s400/5.jpg"/>
</center>
<strike><color=#FF0000>$120</color></strike> SOLD
__________
Set of Hurricane 4-2-1 headers/extractors
An essential upgrade for any N/A K11!
These were bought off ‘nsm’ brand new a few years ago and are no longer needed, so they’re just taking up space. They’re designed for a K11 without Aircon but runner #1 can be modified to suit by an exhaust place as a lot of people on here have had done. Haven’t done it myself so couldn’t tell you how much it’d be to do. The blue paint on it appeared to have been a thin film rather and with heat has come off in most places (see pics!) but it in no way hinders the performance. I’d say it was there just for initial transport so it didn’t arrive looking rusted.
Condition is good. Few minor scratches from install no dints and all the welds/joins appear to be in perfect condition.
<center>
<img src="https://lh3.googleusercontent.com/-...ABFg/8uYCLVmqLVk/s400/IMG_20130204_214848.jpg"/> <img src="https://lh3.googleusercontent.com/-...ABFo/MLTYB4ZO0-s/s400/IMG_20130204_214900.jpg"/>
</center>
Like the flares, it’s a bulky item so pickup is preferred.
<strike><color=#FF0000>$150</color></strike> SOLD
---dens
<center>
</center>
<center>
</center>
$400
__________
<center>
</center>
$50
__________
<center>
</center>
$20
____________
____________
Sold items:
<center>
</center>
__________
<center>
</center>
---dens
