FS: 1994 Micra Super S
TheSam
Buy & Sell Member
Micra Super S 1.3
Tax till July
Mot till 2013
100k
FK Lowering Springs
Bigger Brakes (It actually stops)
Since purchasing I have gone over the whole car, I prefer to know what I'm driving is solid even if its only a run about.
Whole underside has been scrubbed back Stonechipped and under sealed, I had the back of the sill repaired by MysteryMachine (Bruce)
Things Ive done.
Oil Change x2
Oil Filter
Fuel Filter
Air Filter
HT Leads
Spark Plugs
Coolant
Gearbox Oil
Bigger Cat
New Lambda Sensor
Rebuilt the Front Top Mounts,
New Front Dampers
Replacement Steering Rack
New Clutch Pedal
Almera GTi Steering Wheel and Gear Knob
Almera SRi Front Brakes
All bolts around the car removed copper greased and put back in. Adjustable rear panhard rod (Made from a Land Rover steering Arm) Previous Owner Gutted the Back box so its a bit Growly.
Its not mint by any means there are the usual dings/scrapes around the body work from inconsiderate people in car parks, stone chips on the front, the steering wheel is worn along the top and the drivers seat is a bit worn (Seat cover over it) but its almost 18 years old so what can be expected...
It is however a great runner, fires up on the key every time, have gotten 300 miles from a tank of fuel numerous times now.
Its currently located in Bristol
Will get more pictures later, it will come on 14" Micra alloys with a brand new tyre chucked in.
£550
Need it gone quickly.
-Phone-
