TONEY Ex. Club Member May 20, 2005 #1 k11 Q. is there a way to replace the frount ball joint with out replacing the wishbone.
M MTB Guest May 20, 2005 #2 I m8 you done need to replace the balljoint along with a new arm, as far as im aware the arm does have to come off though to install the new one, so only a new joint you can keep the old arm, MTB:].
S super_s Guest May 20, 2005 #3 all you need is the actual botton ball joint roughly £10 just had mine replaced
B Beachboy Guest May 20, 2005 #4 a new wishbone only costs £20 and that will come with new ball joint and the other 2 bushes new aswell. so its a good upgrade in performance terms.
B Beachboy Guest May 20, 2005 #6 buypartsby or something like that, there is a link on MH i found it on.
