Front wipers faulty
The front wipers on my car dont stop at the bottom of the screen when you use the intermitent wipe will replacing the relay fix this or is it somthing else
try cleaning up the contacts for the motor and the relay etc i know some people have done that and it works
if not
then change the relay mate
got one today from the scrappy to try but just had a look and its not next to the motor on mine and I cant see it anywhere.do you have any idea where it would be located?
ahh, i,m guessing yours is a facelift then :eek: (different setup eh)
mine did this on my per facelift, it was a dry joint in the control box, check my blog, the facelift box is under the dash i believe. near the fuse box
