front wing replacement ?
Hi folks looking at changing the wing as other is rusting , is this an easy job ? or is it not so easy any pointers ie hidden bolts etc cheers for any help on this matter meloned.nissan micra k11 x reg
Im not an expert this was the first time i did this to my micra.
I was driving along when out of no where a wacking great range rover backed out on me , this is the damage and how i am repairing it...
1. jack up the car remove wheel.
2. remove inner wheel arch ( sorry no pics) there are 4 or 5 screws to undo ( use a star ened screw driver ( theres probly a proper name).
3. remove wing ( note you do not need to tack the bumper off if you have small hands) all places were the wing joins to the car use a 10mm socket.
4. acess damage for me i had to remove headlight, battery/casing, coolant bottle and the cool air feed . this is easy peasey just un plug everything and look for bolts to remove ( 3 on light, 2 under battery, 2 for cool air pipe behind it and 2 for coolant)
5. i used a hammer and a block of wood to repair my car and bought a new paenl for £40
6... more pics to come
hope this helps abit
