Front wheel +ve camber
skymera
Brutal Honesty
My driver's side front wheel has a bit of positive camber and it's bugging me!
I've seen some pics about drilling the top hole on the strut, but I have no drill. Just a half rounded file
I imagine it's where I slotted the holes to make the Corsa C coilies fit.
Can I file the top strut holes to even up the camber to the other side? Which direction I would need to file, towards the car or towards the wheel?
far easier with a drill :) i fit the drill into the tophole, then turn it on at the same time as lifting a socket and extension on the shaftnut
In that case i'm looking at 0.5-1mm to get them straight.
Probably wont have access to a drill so might just sit there filing away for a while.
Going to buy camber bolts eventually.
Here's my coilies, top hole looks largely "oval"
Can I just loosen top bolt, jiggle the hub and retighten?
I've had these almost an entire year and never even knew. :rolleyes:
Well that answers my questions about slotting. Close thread, solved :D
