Happy Chap
Hi guys
I had four new tyres fitted and asked for the wheel alignment to be checked, unfortunately the drivers side wheel bearing is shot so unable to align, passenger side fine.
I am looking at replacing with s/h part have a 2001 1.0 hub on ebay for 15.00, will that fit my 1.3 june 1998 car?
I did ring but the guy wasn't sure.
I am thinking of buying a new wishbone and track rod end 34.00 total so that I can just cut the track rod end and lower ball joint off? As I have minimal tools is it possible to fit a new bearing myself? As I will have to get the tracking done would it be a good idea to replace both.
Also the other day whilst turning around in the drive the brake pedal was suddenly soft then back to normal I am not losing fluid, which is only 1 year old. I bled the brakes and still the same problem. I know what it feels like when the servo fails, brake pedal very hard but not a lot of braking so I have concluded the master cylinder seals are leaking. I have again sourced from ebay but is it difficult to fit a repair kit?
Thanks guys
Thanks guys
