SuperUno Buy & Sell Member May 16, 2010 #1 I am swopping a 1.3 engine into a 1.0 car, are the sub frames which run front to rear and the gearlinkage bolts onto the same ? Length wise they look very similar, but the 1.3 sub frame look a little different in height ?????
frank Club Member May 16, 2010 #4 SuperUno said: Both are pre '98 Click to expand... then its all different
frank Club Member May 16, 2010 #6 SuperUno said: Ok - thanks Are the removable mounts the same ? Click to expand... the alloy g/box mount is a different shape matt iirc (as are the captive nuts in the support bar) are,nt you only changing the engine tho ?
frank Club Member May 16, 2010 #8 SuperUno said: No, both the engine and box. Click to expand... in that case you need shafts, support bar, mounts/brackets and rods also matt
OP OP SuperUno Buy & Sell Member May 16, 2010 #9 Got all that (got a 1/3 donor car) what is the support bar ?
frank Club Member May 16, 2010 #10 SuperUno said: what is the support bar ? Click to expand... that front to rear cross member/subframe that we,ve been talking about fwn
S Sparcoxs Buy & Sell Member May 19, 2010 #12 Why are they all different then? I thought they would be the same as I didn't think there was much difference. Sure I recently put a 1.0 front to rear subframe on my 1300 rally car before a road rally as my rear mount was finished Cheers, Rob
K k6pfs Ex. Club Member May 20, 2010 #13 I've just added photos and advice for strengthening on my blog for this!
