I know it's an old thread, but issue is the same: front ARB (sway / stabilizer / roll bar) links on my 1997 K11 do not fit.
Original part:
All new parts I found look like this:
I understand you guys advise to cut/skip the central spacer, but the following issues still remain:
#1 - the new ones have an M8 bolt, original was M10
#2 - the rubber on the new ones does not go inside the roll bar or wishbone, so basically there is direct contact between the wishbone-bolt-roll bar. Also because of #1 there is now an M8 bolt in a 12mm hole...
So really,
these do not seem to fit in any way (bolt, spacer, rubber).
Is there not a known good source for these links? I already ordered 2 sets with the "correct" photo, but wrong part, actually.
My best bet at the moment is to reuse the old rubber with a new M10 bolt and 5mm spacer, but i'm not liking this...
