Hi MSC !
I'm Chris from France and i will try to present to you my
cheap turbo project (maybe the first in France ?) on my 2000 K11 CG13DE.
(i hope you understand my "frenglish"...)
This car is a "test car" to learn "turbocharged=>NA ECU tuning", welding...
I've got some pieces from other cars to build this low boost project:
old CA18DET 200SX T25 (too big ?)
GA16DE injectors
GA16DE throttlebody
QG18DE Almera injectors
CGA3DE fuel rail
Peugeot (C4?) intercooler
Cheap air intake
Spare CG13DE
Innovate MTX-L wideband
old VDO gauges (oil press/temp + volt + boost + tacho)
So i'll make my own top mount stainless steel T25 manifold (+elbow) to fit stock downpipe
(i hope stock exhaust is not too restrictive for the turbo... i'd like to set 0.4/0.5bars on the first old CG13).
And put GA16DE throttlebody + QG18DE injectors on CGA3DE fuel rail + install a Nistune daughterboard.
I hope everything can be fitted on this engine...
I have some questions:
- I can read here that a lot of people bypass the coolant hoses on the throttle body. Why ?
- Where I can put my coolant turbo hoses ?
See you there,
Chris
GA16DE injectors
GA16DE throttlebody
CGA3DE fuel rail
Cheap air intake
Spare CG13DE
See you there,
Chris
