you will probably need to remove your ecu and enginebay loom, and then fit the sr ecu and engine loom damian,
but there will be a lot of cabin loom splicing to do tho, because the ecu and engine loom have a lot of inter-connections with the cabin loom (ign switch/dash/fuelpump etc)
