Hello, I have just got my micra, and am looking to change the old steelies for these, does anyone know if they would fit on a straight swap or would they need work before installing (ie to the pcd). They look like fiesta mk 4 wheels.
Measure the center hole, it should be equal or bigger than 59.1 mm. The PCD should be 4x100, I think is the case with Ford, but better check to be sure.
Thought there were some 4x100s. Then the difference it's way too big to use those centering bolts. Just find any other wheels, OEM ones should be cheap. Reanult and Nissan have some good looking ones.
