cisco
» CMF MemberI have the entire bolt-on unbustable drivetrain package sitting in my garage right now, and I'm selling it!
For all of you turbocharged/supercharged micra owners, this might be an opportunity to score a whole pile of gear which was a major hassle to build up myself over time, all in a single package together with everything you need to bolt your car back together and drive it.
The kit consists of:
With this entire package, you can bolt up the gearbox, driveshafts (brand new with fresh rubber boots), hubs and away you go. Its everything you need to bolt the car back together and drive off.
It took a lot of effort and hassle to get this setup made up for my car and it was very expensive. Now you can have it all in one easy convenient pre-assembled package without any of the hassles and running around! Its proven that it works perfectly.
The custom shafts are a work of art and are worth an absolute fortune. The splines and everything is machined to total perfection, and they cost approx $2200 for the pair including the CV joints and all the machining work. The gearbox is worth approx $400. The hubs are worth approx $100. So all up this package is approx $2700 worth of gear.
Open to offers.
- RS5F31A 5spd manual gearbox from N15 pulsar. Gearbox is only 40,000km old and being N15 is extremely modern and new. Various minor improvements over N13/N14 versions, i.e. revised selector fork. Drives and feels super perfect and stronger than ever. Its a great box. The taller ratios are very useful for those micras pushing excess power, you can cruise in 5th gear at more sensible RPM too. This gearbox will bolt straight up to your CG13DE micra engine with your existing flywheel/clutch/starter-motor working perfectly.
- N14 speedo drive sensor. This will make your micra's speedo hook up to the N15 gearbox.
- Ridiculously strong 35mm custom driveshafts. These shafts were made to fit this gearbox to the micra. They will never ever snap/warp/twist. They are built up with super strong 2litre SSS pulsar rzeppa-design CV joints, and appropriate boots to fit in the micra without rubbing on anything. So the CVs are also super strong. The outer CV housings have specifically been machined down to fit snug perfect into the micra's hubs. This combo all works perfectly, turning circle is unaffected with this setup - its just great and you will never kill these CVs either.
- Pulsar 4x100 hubs. These will fit straight inside your micra hub-carriers (stub axles) without worry. They are a direct replacement fit of the micra hubs. These hubs ernable the larger custom shafts from the pulsar gearbox to fit. The spline is larger than the micra one which is also a strength advantage.
Open to offers.
