Fog lights
What would be better yellow tinted fog lights,standard or led
  • Led
    Votes: 0 0.0%
  • Normal
    Votes: 0 0.0%
  • Total voters
    2
right just order a set of fog light for a 2001 micra 1.0 fog lights are of an Almera anyone know if when replacing the light stalk over it is just take one off put the other on and a relay and fuse (if needed) in and they will work fine
Hi retro fitted fog lights from a 2002 1.4SE+ to my 2002 1.4SE, my SE had the wiring loom already in it, I swapped the light stalk from the SE+ which fitted straight into steering column bracket and also I "robbed" the blue coloured front fog relay from the drivers side interior fuse and everything worked! :)
Andy :D
T
Andy :D
thanks a lot just wanna make sure it's that easy as want them done as soon as possible do I know they will be ready
