FLANGE
pork
Jus a quickie, bike carbs all cleaned up, got flanges,
Now, bike carbs are 45mm, inlet on head is 30x33mm.
Should I connect the two with a tapered to fit pipe, or can I take the easy route and just use a 45mm tube to connect it up?
Beings its gunna be pressurised, I wasn't sure if the fact that it won't be a flush fit, it might cause some sort of restriction, or turbulence, or am I worrying about nothing?
Dam it :D
No easy route for me then :)
Would it effect quite badly then if I didn't do that?
I suppose if I'm doing this I might as well do it right ay?
