FK Coilovers from madmotors.co.uk
cool-cool, have you got bsr ones? how long have you had them them on? and have you had any problems with them or anything? how much adjustment do you get with them? cheers
Not yet, but saving. Ask skinner for details. All u need to do is look at h701 blog for his build quality
I've had mine about 3 years, had knocking issues at first with thrust bearing and cup design, but that's been rectified, other than that had no negative reports on anything else
As with all coil overs the require maintenance to prevent siezing.
Height adjustment is approx -90mm standard but can go up or down another 120mm
Just abit of info :)
