fitting vented brakes
Dr Zoidberg
got my brakes today :)
are they easy to fit? simple old ones off new ones on (remembering the spacer/washer).
then bleed the brakes/refill fluid?
had a look at the other threads and seemed easy enough just wanna make sure :)
Pretty sure there was a guide on how to do this mate, but think it was on the old server. Speak to James or Ed, and see if they can look into it for you mate.
Titch
hmm i can be dense sometimes :( theres one in the k11 guides section
i pay my money to look at guides etc and then forget they there :D
cheers titch :)
They are really easy to fit, you just need some time, a 2mm (IIRC) spacer and a socket set and a brake bleed kit. Follow the procedure in Haynes and you can't go wrong :)
