I have a 1.0 k11 with coil packs, i can not afford to fit aftermarket ecu to disable rev limiter at present.
I have two 1.3 camshafts from a donor. I am told that fitting only the inlet cam will increase mid range power while fitting both increases high range power.
Does anyone know the bands of power increase at What engine speeds so I can benefit best from fitting the inlet cam or both cams considering the limiter is not disabled?
