Fitting new parts
CMF_Lx_Micra
So guys ive ordered the following parts and am waiting for them to arrive. Ive ordered :
New Throttle body
New Distributor
New water pump
New thermostat
New iridium spark Plugs, MAGNECOR KV85 leads,K&N air filter
does any one have any hints tips or links on installing any of these part it would be helpfull. I have the haynes service and repair manual is that sufficient enough.
Also would installing the Throttle body and distributor make my car run any better as i dont have any problems as yet.
My water pump has an o-ring leak which ill fix and keep as spare, and the thermostat is stuck open.
CMF_Mike R
I would fit the pump and thermostat first and check all is watertight again .
Do the plugs and check the car runs ok with them .
fit the filter and leads , keep the new dizzy safe whilst you suss out any problems that could mess up the new TB .
Do the dizzy and again check the car still runs ok .
then fit the TB and check the car runs ok .
bag up the old parts as spares .
nothing worse than fitting a load of new parts to find the one of them dont work properly , or wrecking a newly fitted part whilst working on somat elese .
CMF_Lx_Micra
ohhh ok I assumed it was on the actual pump. The problem i have is it leaks few drops from time to time havent seen any lately but sometimes it will leak and other times it dosent. i havent been able to track where the leak is exactly but it is around the water pump so i assumed from looking at the forum that it is an o-ring on the water pump.
So your saying theres an o-ring for the steel pipe behind where the pump sits, how hard is that too to fix.Does anyone have pics of this, im gona start looking for a thread on this from the past if there is one on here.
CMF_frank2
the O ring seals the pump end of this steel pipe, that runs under the inlet mani (which is held by 2 x 12mm bolts iirc)
