fitted aftermarket steering wheel
CMF_niiCk
1300cc WROTE:
"the kit came with all the usual parts, but there was 2 pins included but dont know where it goes, it came with instructions in jap
those two pins go on the bottom of the bosskit.
if you look at the back of the bosskit there are two holes.
These two pins are for the indicator cancel.
they need to be positioned at a 10oclock and 4 oclock position.
CMF_1300cc
thanks niick, fitted the 2 pins, shorter one on the left and longer on the right....all working...
CMF_niiCk
1300cc WROTE:
"they are not of the same length, may the longer one will be the 10'oclock position....thnks
1300cc WROTE:
"niiCk WROTE:<BR><BR><BR><BR>those two pins go on the bottom of the bosskit.<BR><BR>if you look at the back of the bosskit there are two holes.<BR><BR>These two pins are for the indicator cancel.<BR><BR>they need to be positioned at a 10oclock and 4 oclock position."</DIV><BR><BR>thanks niick, fitted the 2 pins, shorter one on the left and longer on the right....all working...
Sorry i couldnt get back to you earlier to answer your previous question but im glad you got it fixed:)
anytime..
