manifolds:
are 1.0 and 1.3 standard manifolds the same or are the bore diameters different? if they are different, will the 1.0 manifold still bolt straight onto the 1.3 head?
mounts:
which mount needs changing when doing the 1.3 conversion? if any mounts at all.
driveshafts:
1.0 driveshafts should be able to cope with standard power 1.3? right or wrong? shouldnt see a problem myself.
brakes: i hear 1ltr and 1.3 brakes are the same, is this correct?
gear linkages: are the gear linkages the same, e.g the bit that goes from the stick to the gearbox to select gears.
cheers in advance
mounts:
driveshafts:
cheers in advance
